Originally posted by Garycar
If I'm not mistaken the factory recommended 10-30 for the turbo Regal. 5-30 may be suitable for extremely cold climates and in my opinion 15-50 should never be used on a Turbo regal. If you look closely at a contained of 15-50 you will see that it does not contain the star burst symbol. That symbol is the petrolium industrie's standard for efficiency. Most wear occurs at start-up. 15-50 oil just doesn't flow well at start-up. don't use it!
Just some further comments as we have been looking into the "best" oil to use. Since there are many different situations of use and engine build, the term "best" may be different for use in the various catagories. My interest here is primarily in performance and relability with extreme use, not normal street driving.
To address the above comment that "most wear occurs at start up", the synthetics will drain off bearings in a few days. This will be more of a problem in occasional use T-R's. The factory engineers I discussed this with were also in agreement and would rather not use synthetics for vehicles that sit a week or more w/o being started.
Since the Buick recommendations were made 20 years ago, many things have changed, especially the additive package in oils. This is especially true of the heavy metal, anti-wear additives. This is why for years we have used the GM Engine Oil Supplement [EOS]
in our cars that are raced.
Our race cars and "weekend warrior" cars probably never see more than 300 miles w/o an oil and filter change. In this situation it make no sense to use the expensive synthetics, and probably better off using race oil as it contains more anti-wear additives.
Synthetics have been used with no problems by many owners. Having rebuilt many motors with over 100K miles, if they have had good regular maintaince, the condition of internals are very similar with either synthetic or regular oils. The only aftermarket cam we have had go bad was one that used synthetic oil?
For years we have used Kendall oil, but is is hard to obtain and is now going to the new "SJ" spec which has less EP additives. Our oil of choice now is the Valvoline Racing. There is a trade-off in effiency between gas mileage and reliable performance so we are not concerned about the "effiency" rating.
