pacecarta said:TURBO REGALs are the only true doners for a swap as gears are 3.42
HURST OLDS and 442s have 8.5" but those have 3.73 gears
finding one in a junkyard doesnt happen much
better chance getting one off this board as they pop up regularly or you can call bob hebert or brian weavy
Are you looking for an 8.5 posi rear or 8.5 open rear? I may have few open rears left. Either way they are not cheep and it's very hard to find them at the bone yard. All the guys with G body cars are after them. I may have sold over 20 rear ends in the last three years. It's a hot commodity.BandAid said:I have a NA Regal with a 7.5 rear and no posi ,want to find a junkyard rear and swap it in....prefer true bolt in rear...
Dennis
turbo nasty said:Seriously you can build the 7.5 and it will be mean.
Several guys at the drag strip here have s-10 trucks and blazers with VERY strong small blocks and 250 shots on em, 2 guys have a 2 stage setup around 350 total.
And running 7.5 with higher count axles and a spool or strong posi unit...some do not even have the girdle rear cover.
I am talking the front tires (both) are toted off the line and these guys are running in the 10's several times weekly.
Just an option plus the 7.5 built will be a bit lighter than the 8.5
84-88 monte ss's had 7.5 rears, and had 3.73's in em'Blazer406 said:By the time you spent enough money to make a 7.5" that strong..... you could have an 8.5" with some Moser axles.... that is definately strong enough to go 10's.....
I also thought maybe the 86-88? Monte SS had the bigger rear end... and they came with the 3.42's..... unlike the 442 that had 3.73's......
just my 0.02
