Jul 12, 2009 #1 B BandAid Keyboard Bully Joined Oct 4, 2004 Messages 3,964 Looking at the spade terminals inside and it looks like there was somethink plugged into it....this is located on the passenger side interior ,under the panel below that crappy glove box on the dash.. Attachments 0712091408a.jpg 52 KB · Views: 137
Jul 12, 2009 #2 J Jan Larsson Active Member Joined Nov 22, 2001 Messages 2,151 That should be the antenna relay if I remember correct so the missing plug should come from (I suspect) your antenna.
Jul 12, 2009 #3 B BandAid Keyboard Bully Joined Oct 4, 2004 Messages 3,964 thanks as always Jan..I have a few more teasers for you,check back when i load pics..
Jul 12, 2009 #4 garyk1970 Electronics Moderator Staff member Joined Nov 4, 2005 Messages 4,330 x2 power ant relay....the wire(s) with the green,white and grey in the pic above is the actual wire that is supposed to be pluged into it....
Jul 13, 2009 #5 B BandAid Keyboard Bully Joined Oct 4, 2004 Messages 3,964 garyk1970 said: x2 power ant relay....the wire(s) with the green,white and grey in the pic above is the actual wire that is supposed to be pluged into it.... Click to expand... thanks everyone..I just glanced at the wire above ,they looked like they were plugged into the relay also ,not just jammed above the relay... hehehe
Jul 13, 2009 #6 garyk1970 Electronics Moderator Staff member Joined Nov 4, 2005 Messages 4,330 BandAid said: thanks everyone..I just glanced at the wire above ,they looked like they were plugged into the relay also ,not just jammed above the relay... hehehe Click to expand... cool...alot of people unplug this wire (here or under the hood)to stop a broken ant from running on and on.........
