What size banjo bolt for front brake hose to Blazer S-10 dual piston caliper?
d0n_3d
Boost is good.
I just finished my 11" bolt on upgraded front brakes and need the fluid bolts that connect front hose to calipers. Are all GMs from that era the same size bolt?
I found out which bolt it is. Dorman part number 13940 found at your local auto parts store. Its an M10 x 1.5 banjo bolt 11mm hex 22.8mm length. Not sure if this is stock on our stock GN calipers but it says on the package GM 2007-1979 so I would assume it is.
