This is what my proportioning valve looks like. It's the brass style.
I am in the middle of installing my Biondo line lock to meet NHRA specs, meaning I'll be running a line off the proportioning valve into the line lock and then on to the front brakes.
I want to retain my stock brake line fittings at the proportioning valve in case I ever want to put it back original. (meaning no more line lock) However the fittings do not fit the brass fittings I was told here to purchase.
The tee inverted flare, 130333, which I was told to get, does not allow either of stock line fittings for the front brakes off of the proportioning valve. Also the pipe plug I was told to get, p/n 120300 when screwed in to the proportioning valve, allows brake fluid to leak.
All of the brass fittings I purchased are the Edellmann fittings.
So does anyone know what size/thread count are the fittings that screw into the proportioning valve, that go to the left and right front calipers?
Thanks in advance.
