What trim is this wheel?
measurements...
sorry for the vagueness....:o
Inducer measures (bigger part of wheel)-2.8930
Exducer measures(smaller part of wheel)-2.5180
I measured from fin tip to fin tip. Correct me if I got the ex and in mixed up.TIA
I get a "not logged in" error when I try your picture link. The trim is 100*(2.518/2.893)^2 = 76 trim. If this is a turbine wheel it looks like it might be a TO4 P trim which is 2.544/2.922 and 76 trim. I've seen these dimensions vary by up to maybe 0.010" between different manufacturers' catalogs; I've listed the PTE size, so if you were a little under on the 2.518 it matches up pretty well.
Wanna sell your turbo? do you think it is a 70? I see it is a 3 bolt. Any idea the A/R of the turbine housing?
A/R
The a/r on the exh. side is a (.63) and the comp. side is a (.55) as per etching and markings.
It's the turbine wheel on the exh. side. I just noticed I never specified that. Sorry about that.:eek:
