what turbo do you guys recommend !
esm
i have a 10.4-10.5 goal --- i have a fresh long block -- 50# injectors and alky
stock ported heads - 218 hydraulic cam -stock ported intake 3400 art carr
converter with a 200r4 transmission ---full weight car --- im leaning toward a turbonetic 66 but would love some info -- thanks
I am looking at the same ET and I don't think the 50's will get ya there.Safely.
Well maybe once.
I am thinking 6265 or 6765 billet
need to step up to 60lbers the 50lbers may get you there. but you need to check the dc duty cycle i imagine you will be pushing youre luck. its better to be safe than lucky!but than again if you have several 109,s laying around go for it turn up the boost. roll the dice see how lucky you are!
info
been hard enough to get to this point so i have to but wisely and 60lbers if needed
Well maybe once.
6765 billet the way to go. if you have Xfast? 83lbis the safe way to go.
esm,you don't need a billet wheel to run 10.5's,the 66 is more than plenty and you can keep the extra $ and upgrade the injectors or grab an alky kit from razor and keep the injectors you have.
50's with alky are more than enough to run 10.50. Probably work down to 10.20's if the car wasnt over 3600. I went 10.29 with a t-netics 66 s trim on a tired 147k engine.
thanks
i want to thanks all of you for the info and help ------ this is the best web site and has the most helpful members !!
