well i recently was brought over to the dark side and im loving it, but my car hasnt run the times that it should
. i have done the spring cleaning maintenance stuff so far, and changed the fuel pump to a walbro 340. but as i am told by the previous owner, that the turbo does not spool up as fast as it once did. he told me that he traced the problem to the EGR valve, i havent got around to changing it but i dont imagine that the EGR would cause the turbo to spool slower than normal. has the turbo just gone bad?? i havent checked if the shaft has a lot of play in it yet but are there any obvious solutions to this problem. it makes a good amount of boost around 15-16lbs (stock turbo) at the top of each gear so im guessing the turbos working properly, but the previous owner tells me that it spools much slower than before. sorry for the book just trying to get my TR clocking the times that it should, thanks.
