Re: ENGINE PRICING???
Originally posted by Chuck Leeper
Alan, I'd expect to see a dyno sheet included w/ an engine that I'm paying hi bucks for.[Relative to home built].
I have another question concerning the poll... Do the prices you show take into consideration the builder supplying the block, crank, rods, heads?. Dyno test? warranty?
Other prices that I've paid around Atlanta are:
Assembled short block $450. [He Screwed it up!! Put std brgs on a .010 crank].
Dyno testing $450. [PS: I have a BRAND NEW dyno harness from Caspers for sale!!] Never used it after he FUBAR'D my short blk.!
Rebuilt heads w/ stock valves and a multi angle valve job. $230
FWIW, IF the crank grinder guy is doing it RIGHT, he should be checking the stroke and index when the crank is put in the grinder. Costs more to do it right??
Put my vote in for "OVER $5000".
DAMN!! And it costs< $4000 for a SBC crate motor that makes 450 RELIABLE HP!!! Whats wrong w/ this picture???
Back to "lovin on my stage 2"
[AND crying over my checkbook!!]
I was not really thinking about dyno testing, and I was more concerned with what people expect to pay if they carry their production engine to a shop and say "build me the best possible engine based on a stock block."
As far as dyno time goes, I only charge $250 to start an engine on the dyno to break in the cam, check oil pressure, check for leaks and other problems. To break in an engine enough to run a power pull on the dyno takes a while, and dyno time isn't cheap. I will not make a power pull on a tight engine, it ruins them, dynos are hard enough on engines without abuse. If you figure $250 for installation and check run, and $100 an hour for four hours of breakin time, and $200 for an hour of power runs, you hit nearly $1000 for dyno time.
Sure, you do have to set up a crank to grind it, but there is a difference between grinding a crank to get the journals to proper size and finish, and grinding them to correct stroke and timing. Indexing and equalizing also most often requires grinding the crank 0.020", and few people want to pay for the extra setup.
As far as warranty, the "general" policy is "no warranty on speed work", but we know that no reputable shop follows that. It's very hard to explain our policy, let's just say that in 20+ years, very few people have been less than satisfied. If WE screw up, we make it right, period. We ate nearly $50K one year when Comp Cams had problems with their cams. Wasn't our fault, but we fixed it anyway. Even on engines we didn't assemble OR break in. If we did the work and supplied the parts, we made it right. It took three long years to make it up.
