Franks86gn
- Nov 15, 2011
I would estimate about 100 passes at 25-27 # boost
SignUp Now!I would estimate about 100 passes at 25-27 # boost
what is this?? i was looking into a ratchet shifter to prevent pushing too far, unless something is available for the stock shifter??Do you guys uses the special detent plates for factory shifters with your Stage Right?
http://www.gbodyparts.com/product_info.php?products_id=589what is this?? i was looking into a ratchet shifter to prevent pushing too far, unless something is available for the stock shifter??
I used the Stage Right T-brake for 2 seasons. Stock U-joints/driveshaft/rear end/axles. Convo pros screwed to M/T ET Drags. 45k miles of light use until I bought the car.
Before the t-brake, my vacuum brakes would not hold 3psi. 1.70 sixty foots all I was getting with a 12.0 ET. Put the t-brake in... BAM! 1.45 - 1.52 sixty foots and 11.50s all day long. Plus it's a lot of fun!
I'm sure I'll be breaking driveline components soon as I plan on continued use.
i would say use a leaf switch mounted to the detent plate....Another question for you Stage Right users. Anyone know of a way to mount a micro switch to the shifter mechanism so that when its in 1 (and trans is braked) the switch is tripped so that it could trigger a 2-step?
so, looking at that detent plate, it lets you go from 1 right to 3, so do you hit it to launch then pull right back to 2 til you're ready for the 2-3 shift?
i usually run it out a little longer than where it wants to shift on it's own.No you just let it shift on its own once its in 3rd
not stock anymore...
My brakes are bone stock except I pulled the PM off and replaced it with a JY HB unit off an astro van. My car left on 14 psi+ last time to the track on the foot brake. If you can't leave on plenty of boost off the foot brake, your braking system is not up to the task.
I do agree however, the TB "shocks" the drivetrain...and tires and stands a much better chance to get a better 60' time.... albeit at the expense of weak driveline parts.
