- Jun 28, 2001
I agree. Let Paul run.
SignUp Now!Mike, I was just gonna make a 71.5mm round plug out of uhmw. Has to have a hole in the middle for the wheel nut. It should be snug on a 71 and not fit a 67. Ill chip in on material if you wanna make it.
Will I be the only 10 second tsm car next year? Lol.
• Maximum size compressor wheel inducer size is less than 71.5mm. Inlet bore cannot exceed 72mm to allow for machining tolerances. Maximum compressor wheel exducer size is less than 103mm.
• No sleeves, welding or cold weld epoxy on any exterior surface of the turbo compressor housing to allow a larger than legal “70mm” compressor wheel to be installed is allowed.
I thought that you pulled out of this deal? I don't think we will be bringing a car after all.I have the rings to measure both inducer and exducer for both turbos. I had them made when no one could produce the original rings or plug. I'll have them in BG in case someone protests. Not that that will happen. I plan on running a 67 at BG so I'll measure and double check both turbos I have before then.
It would be nice to have 2 classes Tsm and Xtsm. and this is just saying most tsm cars run in the 9s so to make things fair for everyone we should make xtsm a 8.90 or faster index i think it would bring more cars to the events just a thought Jason.Nothing against you bud.
Back to my original reply, To keep Mike E from having to make rings, I already have some and will bring them to BG.
John Plog and Randy Alexander will be slugging it out.Make Jason run TSO!! lol.
The GSCA is not gonna recognize two tsm classes.
