What's my next suspension upgrade?
Drew L
Gerry Attrick
I have all of the braces and bushings. It's a "stock" t-top car so what's nexT? Thanks. Drew
Box your upper and lower control arms in your rear suspension and install LT1 or polyurethane bushings.
Buzz White in Houston, TX (sumnerw@flash.net)
I have four new KYB's also (I forgot). What about the sway bar I see so much about? drew
What is your use for the car? Is it mostly drag, street/strip, street only? If you want handling on curvy roads, you will end up with a different set-up than if you want it for the strip. Give us more info..
"Air Lift" air bags in your rear springs. They are $65 for the set from Summit or Jegs, and they greatly improve launch.
I'd go with boxed or tubular rear lower control arms after that.
Ross
