philosobrad
- Apr 23, 2004
So, I just got my car back after sitting for years. 86 T-type, Just had fresh engine build with .030 overbore, 210/210 cam, ta-49, 42.5lb injectors, Walbro pump with hotwire, thumbwheel chip for 42.5 injectors (other specs unknown). Otherwise the car is stock for now. The rebuilder added an AEM A/F guage with 02 sensor mounted in the stock downpipe. At idle the AF gauge reads between 12.6 and 13. I haven't really been able to drive the car due to a faulty MAF that I'm guessing is causing the rough idle. (the idle goes nuts when you tap on the MAF and cuts out bad when you give any gas)
My question is, what should my AF readings be at:
Idle, part throttle, WOT?
Thanks in advance for helping a willing new guy. I'm paying attention here.
