TA-66 GT-Q journal bearing is correct. This was the class winning turbo that was used on TSS class cars, before they changed the rules to allow 67mm compressor wheel and an E cover into the class.
87NAT
You answered well young grass hopper..
Just to add more.
Only the Garrett dual ball bearing equipped turbos, such as those sold by PTE, and other Precision dealers, require water coolant lines as well as an oil feed line. A few of the most popular turbo models are these, PT6031RE, PT6131RE, PT6131RS, PT6776RE, PT6776RS, PT6776RH, PT7080RH, PT7280RH, PT7480RH, PT7680RH.
The T-netics ball bearing turbos do not necessarily have to have water run through them. Those still use the oil somewhat in order to cool the cartridge down. Sometimes you will see the T-netics turbos with "Wet" bearing housings, sometimes they will have standard oil cooled bearing housings with no water provisions. Here as of late, most of the new BB T-netics turbos I have seen people post pictures of, have the water coolant passages. I'm sure it comes down to whatever they have available at time of order placement. Jack has received the T-netics bb turbos both ways. It doesn't hurt a thing to run water through the T-netics turbos either, it only helps them live longer.
HTH
Patrick
