What’s the safest way to cleaning the injector bores on the intake manifold wile the
What’s the safest way to cleaning the injector bores on the intake manifold wile the intake is installed on the engine?
Maybe a nylon round brush with some solvent
Then blowing it out with the compressor.
wow
i can't believe every one pulls out the intake manifold to clean the injector bores.
or
that nobody cleans the injector bores on the intake manifold when replacing injectors.
HELP
I would think that a small detail brush and or firm tooth brush, some penetrating solvent or simple green undiluted combined with a shop vac would knock this project out with authority. No matter what, the shop vac would be mandatory to me.
HTH
Patrick
Compressed air in each port before pulling the injectors. Spray some brake cleen to loosen the dirt.
I just clean the o-ring seats with a solvent (Prep-Sol) and q-tips, then WD-40 the bosses before installing the injectors.
strike
