Whats Up With My Trans??
JUSTAV6
Getting High On PSI
I Just put a Junk B&M Shift kit in and a 9x11 stall, And Now it has a deleyed shift and wene it wants to go into OD it acts like it slips,
But its not, If Shift Frim But its delayed?? Could it be the TV cable?? Or What??
Please Help I Need to Fix This By Friday. I'm Going to the track..
Thanks For the Help,,
Seneca Lafler,
shift
try to adjust you tv cable one click at a time it is a pain in the but but some trannies are picky hope this helps:cool:
Re: shift
I Did That Out And In, But It Dont seem to help it any, It does change the frimnes of the shift,
Thanks For The Reply,
Seneca Lafler,
Originally posted by MeanBuicks
What springs did that kit have you change?
Well my brother put the kit in for me,, But its the Shift Inprover kit, I think it has ya change the PR valve sping with a blue one and the tv sping I think, I called B&M Today and they said it could be the TV valve or the govener some were in that area,, So I think I may check the TV boost valve and go from ther, Or I might just put my spare trans in and give up, If the TV valve dont work,,
I pulled the TV cable off , Unhooked it, And it didnt change??
Thanks For The reply,
Seneca Lalfer
Well from your description I'd say there is a good chance that the TV valve is sticking. Pull the valve body back off and give it a good cleaning.
You might even remove the TV valve line up from the casting to be sure you get everything really clean. It's not uncommon for a valve to stick after servicing the valve body. The clearances are so tight that the smallest piece of grit can become a headache.
Seneca Lafler,
I fix it,, It was the TV ex Thingy, Like an L shape with a sping on it, I pulled the pan and ther it was, A little Baby blue sping,, And I waited for my brother to get home and take a look at it and thats what was wrong with the dam thing,
Thanks For All Your Help Guys,,
I Will Be Going to the track This friday, And I'll post my times, Running street trim with about 25-26 Boost with akly:D
Seneca lafler,
A baby blue spring lying in the pan sounds a lot like a governor spring. They have a reputation for jumping ship.
