I've been working on it.
I put in a new brake system and finally have brakes that can compete with newer sport cars.
I've been working on engine upgrades for years but getting parts that aren't what were advertised made it a nightmare to try and diagnose. One of the worst was a 42# injector and chip combo from Kenne Bell. I fought for years to figure out why it performed even worse than stock. I finally switched to 60# injectors and it got better. Just recently I found the 42# injectors and used them on another car I have and found that I couldn't get that vehicle to run right with them. I sent the part number into Witch and found out that Kenne Bell *ucked me over, these injectors were 28# stock injectors. All those years of fighting problems caused by con artists (and that was just one occasion).
I just recently was getting it tuned in and it all went to shit, knocking and clanging while idling, then running with a little bit of a stumble, and back to the knocking. I turned off one cylinder at a time and found #4 to be dead. I changed the coil on plug, then the wire, with no change, then pulled the plug and found it no longer had a ground strap (first time ever seeing a spark plug come apart) and the center electrode was beat to shit, and ready to break off. So now that chunk of metal has beat up the cylinder, gone through the valve, and is either in the turbo or CAT.
I originally replaced the blown transmission with the Raptor thinking that it would finally solve all the short shifting problems, but once again was just another cluster ****. If the engine isn't toast, then it looks like I'll be taking the transmission pan off again. I messaged Dave H to see if he had any Idea why it's always short shifting even with a completely different transmission.
I've been working with Eric at Turbotweak, and Cotton's through the past few years to get to the point I'm at now.
