I have some detailed injector data on several popular injectors, of fine pulsewidth resolution as well as high pressure testing. A friend paid big bucks for this data, so I haven't given it out freely.
The 50lb injectors held up fine, up until 90 psi. I don't know where everyone comes up with these other numbers. At 90psi, they clammed up, flowed NO fuel, the fuel data drops like a rock to zero. Before that, they are fine. The data was done up to 100psi, and the rest of the injectors worked fine up to that point. The 50lb ones were the only ones that failed. This is the ONLY true data I have ever seen or heard of about the pressure problem. Every other post I have ever seen is "I'm told they lock up at high pressure" with no concrete data quoted or referenced.
They DO NOT respond to fuel pressure in the same fashion as most other injectors (typical pintle & disc style). In fact, if you overlay the pressure data of the 43.5/009 injectors versus the 50lb ones, the 43.5lb injectors will flow as much as or more than the 50s at high pressures (we are talking about HIGH pressures here, like 70-80psi). The delivery does increase, but it is not by the relationship that other injectors follow.
You guys are talking about the differential pressure, which I understand to be the real story. So for you to stop up the 50# injectors, you'd actually have to run 90psi of base fuel pressure, or be using a serious FMU type of setup that increases the fuel pressure at a rate greater than the manifold pressure increase.
Use a boost referenced regulator (as 95% of the people do), set at 45psi base, then run 30psi of boost, your fuel pressure will be 75psi. Your manifold pressure is 30psi. Differential pressure across the injector is still 45psi, which is the whole point of the boost referenced fuel pressure regulator. Unless there is something I am misunderstanding about the cause of the injector locking up, it should be the differential fuel pressure we are worried about.
Brian Green
89 TTA - with 50# injectors
