- May 28, 2001
Probably been asked/answered, but:
What's it do in open loop/idle??
SignUp Now!Haven't done the test personally but with a speed density system I don't think a vacuum leak makes it run lean (so long as the leak isn't in the map connections), it has the same effect as cracking the throttle open a bit. The idle speed will go up and then the ecm will close the iac to get the speed back down, but the afr won't change unless you move to a different commanded afr in the map-rpm table.
Whats the alternator volts showing on the xfi??????????
Haven't looked at the XFI for a while, but recall a procedure that requires you to check TPS v's key on/engine off/0 pedal. Then check @ WFO, and interpolate, and set several points between?? [Low, hi, and 7 in between, to get the tps calibration.]
If I'm correct, has this been done?
Have you verified timing and reviewed some of the other items I suggested?
Jimmy do you still have an EGR valve hooked up?
If so check the egr functions in the XFI and make sure that
it is not commanding it at an idle.
THis happens on one of hte update and it puts
the EGR duty cycle at 100% in all boxes
