You'll need an adapter. By my calculations your backspacing for those wheels is going to be around 6.5". The normal tightest fit for the back is 5" most people use a 4.75" backspacing 18x9.5" wheel. I'm guessing you'll need a 1.75" adapter to mount those on the rear. On the fronts I'm not sure if they will fit but I'm sure you'll also need an adapter.
You could get away with th 8.5" up front but you'll need a backspacing in the range of 4.5. Is there a specific wheel you want? Positive offset is usually not used on these vehicles. Positive is less dish and negative is a deeper dish. You're problem is the +30 mm offset that is going to require an adapter on any wide rim. A +30mm on a 8.5" wheel is around 6" backspacing which is still going to require a 1.5" adapter but it will fit in there I believe.
1 inch to be on the safe side will give you 4.75" backspacing. The wheels will have a 5.75" backspace. Some have fit as much as a 5" backspace wheel but 4.75 is the sure way to go .
100% agreed, if you are lowered in the front w/ springs stay w/ "normal" BS, if you have drop spindles you need 1/2" more to get the tire off the outer lip. like 4.75" BS on an 8.5" front w/ a 2" spindle drop.
