Wheels with slicks and engine parts
avanging 6
Hi,
I've had these parts in my basement for too long and want to find them a new home. All parts are good and are in new or excellent condition.
Shipping is not included and since most of these parts are big and heavy
I would prefer local pickup. All parts and descriptions are listed
bellow with suggested prices will take best offer.
2 Weld drag lite wheels 15x8 with 4 1/2 back spacing $200.00
2 MT ET slicks 28-9-15 with tubes-mounted on Weld drag lite wheels 15x8x3 1/2 back spacing. Never been run $1000.00
1 set of turbo stock heads complete with LT1 valve springs $500.00
1 set of bare Weber polished and ported heads $400.00
1 set of 42lb injectors with 2 red chips-street strip & racing $175.00
1 set of 50lb MSD injectors with 1 Turbo Tweak chip-street strip will run on
93 octane fuel @ 17lbs or with alcohol 25lbs of boost $200.00
1 March under drive pulley set with alternator pulley $75.00
1 set of NO 2 connecting rods that were magged and tested for bend and twist $75.00
1 set of ST TRW pistons hung on NO 2 turbo rods $300.00
1 set of WISCO pistons for a stroker 240 kit $300.00
2 crank shafts rolled fillets polished-both measure 20/20.
Crank that is not tagged is cross drilled and has a light scratch on one
main journal. Both have been mag checked for stress cracks and are OK $200.00 EA
put me inli9ne first for the weber ported heads.
what is wrong with them? any better pics?
thanks
Price on the Weber heads is a *little low*,wouldn't you say?
Wouldn't $600 be more appropriate?
Thats a good deal right there. They are bare though. He can sell them for whatever he wants. PHANTASM beat us all to that deal.
Not yet,he hasn't.
I'm wondering if the prices on the heads are reversed?
I'd hate to see someone get upset due to a mis-understanding over a brain fart.:)
Between valve springs, valves/grinding and setup time they are a decent deal but you would have $400 or more into them if you paid a shop to do it. The seller is asking a very fair price. If you can diy they are a steal.
Kshef
If there 275 60 15 they won't rub
If there the 275 50 15 you will have to use a 5/16 spacer and longer wheel studs
Waiting on more pics of ports and such. What size vale are these machined for?
Would like to purchase them if they check out.
Weisco Stroker Pistons
Interested in the Weisco pistons. These are for a turbo application, correct? Can you provide detailed specifications please
What's the best you can do for them. I live in Michigan. You can PM me if you want.
what would the comp ratio be with 9441 head gaskets?
let me know and i will call you about sending the money.
thanks
