SignUp Now!Who makes the Wiz Bang model? Sounds very intriguing.
Who is the builder?I have a SLIC intercooler, and I am building a decent street/strip motor which the builder suggested I get a front mount, Like RJC 325 or 425 big one. I seem to be lost on what I need
The best time to buy one is when a friend from your car club decides to sell one cheap! That's what I did when I bought my CAS V2, and I've never looked back in the 10 years I've had it. Yes, I had some cooling issues, now overcome. And yes, I seem to be able to run a little more boost on weaker fuel than others (not quite in Dave's category). Most people would look at my combo and say that the FMIC is overkill, and it is. But even at my level, it's a benefit to performance.
YMMV
Sent from my SCH-I535 using Turbo Buick
Just to chime in with a quick observation:
With all the talk of SLIC vs. F/M,has anyone noticed that the OEM's are using F/M's in a big way for their turbocharged engines?
Seems they're after as much H/P (and mileage) as they can get from smaller,more fuel efficient engines.
Of course that involves as big a boost level as they can get as safely as possible to make the smaller engine perform in a big way .
Just throwing that out there.
Did you go from stock to the FM? Stock -> dutt neck will gain a couple psi due to less restriction. stock -> PTE SLIC is an even bigger gain. PTE SLIC to FMIC not sure if there would be much?
To be fair, I went straight from stock to the CAS V2. At the time, I was running my trusty ole' TA-49 and red-stripe injectors with the stock I/C. About the time I was thinking about upgrading, a friend from my car club decided to sell a CAS V2 he had laying around, so I jumped on it. I figured "once I buy this thing, I will never need to upgrade my intercooler again." So far, I've been right. I don't even think the PTE SLIC was available back then (about 2002 or 2003 time-frame).
I do remember reading the famous article by Bob Dick on intercooler testing, and it showed that with the larger FMIC's like the CAS V2, you could get the boosted air back down to nearly ambient temperature with lower pressure drop than with the SLIC's that were available at the time. I'm a big fan of using data to make decisions rather than opinions, so I felt good about the FMIC. The data from the article clearly shows that the cooling offered by the FMIC's was better than the cooling from the stock or SL intercoolers. Cooler air entering the engine equals less chance of knock. Remember, this was before alky injection became popular, so intercooling was all we had. Testing was done on a car that was running low-12's at 21 psi of boost - a mild car by today's standards. The data were taken as the car was running down the quarter-mile, so it's a good representation of what happens when you make a pass at the track.
Here's the article: http://www.vortexbuicks-etc.com/bob_dick.htm
(note that the "TB Inlet" and "Turbo Outlet" data was accidentally reversed in the tables for the stock and Duttweiler Neck IC's)
On the downside, I did have to upgrade my radiator and fans, and I do get the infamous part-throttle turbo flutter/surge at around 10psi due to the huge volume of air between the turbo and throttle body.
Again, YMMV.
Never ran the car down track, issue is im changing the combo I just picked up the new 6466 which will be sitting on a 109 .30 over stroker with a mean set of heads and cam, builder is putting motor at close to 900hp and said should upgrade intercooler so I did RJC325 fmi......
....as soon as you get tired of working around that retarded stock location.
