imjoesnuffy
I just break stuff!
- Sep 13, 2005
Part 1: On a couple of occasions at completely random times my horn started blaring. Went off at 2 in the morning and while sitting in traffic waiting at a light. Smacked the $*#t and it would stop. Embarassing if nothing else.
I took the horn button off and the white plastic tube that holds the end of the spring for the horn is broken off where the tab from the button connects to it. Its down inside the column an inch or so. I need a replacement for the white plastic tube.
Any idea where I can find one? I haven't disassembled it any further, just disconnected the horn.
Part 2: Car died on me while driving, I had just replaced some bulbs in the dash. I didn't know about the volt bulb not working and not recharging the battery. Battery would drain the system slowly. Pushed the bulb in further and problem was solved. Found this out by searching on here.
Now the right turn signal in the dash stays illuminated when the lights are on. When I use the turn signal it will blink. The PS marker light in the headlight bezel won't come on when the parking lights and headlights are on. It will blink at all times when the turn signal is being used, it just doesnt come on with the lights on???
Dash issue, turn signal stalk issue or light harness issue? Any way to isolate the problem based on my description of the problem. I have checked the bulb and the harness as far as I can. Not a major problem just annoying and wanted to see if anyone else had dealt with this.
