Where is the Green MAP Wire???
Blown&Injected
Looking for the connector that has the green MAP wire for the PAC but I do not see it.
There is a Pale Green wire soldered directly to the back of the Tack/Boost gauge and the only other connector I see in the area is a vertical flat connector with 6 places - only the top 5 are used and none of those wires are Green:confused: :confused: :confused:
If I can't find it under my dash, I will look for it near the glove box.
I do not have a digital dash.
There are lots of green wires under the dash and the colors seem bright but I'm wondering if the bottom wire is the one I need - just faded. It looks gray with some maroon spots
Forget about that plug by the tach/boost gauge unless the engine and trans is out and somebody chain sawed a manhole sized access hole in the firewall
Going for that plug behind ther glove box
I just tie it in at the MAP sensor. Less than a few seconds.. done :)
