BLACKHAWK38
- May 26, 2002
I have heard that PTE has a new intercooler and also Mease performance, just like to the specs on them and some pics.
Thanks and Regards : Blackhawk38
SignUp Now!Originally posted by BLACKHAWK38
Originally posted by d0n_3d
...we guarantee it!
Originally posted by turbo nasty
If you lose to a honda, mustang or mini they give your money back....hah...hah..
Originally posted by bruce
Exactly what are the conditons of this guarantee?.
oh I don't know...maybe something like if you aren't satisfied with it then return it for a full refund no questions asked? It's simply an awesome intercooler!
the intercooler is a DIRECT replacement of the factory intercooler...you have to put on a new bracket which utilizes a water pump bolt and spacer and the shroud fits over the front sway bar but the intercooler should come with good instructions and it's very easy to install...it doesn't matter what downpipe you have...also it comes with the correct hoses because you specify what turbo you have when you order...give us a call and we'll help ya out![]()
Originally posted by jsta6
There is a thread on this intercooler complete with instructions, tips and pics. Do a search.
I think it works great. Seems to be a lot less back pressure.
(hijack thread)
Don, I have the 36mm 1LE camaro sway bar. My shroud has about two inches of clearence above the sway bar, but the bottom was rubbing on the sway bar and making an awful racket. I had to wedge a peice of rubber in between the shroud and swaybar. FYI if you guys want to make a change to future shrouds.
GREENBACKS, MOO-LA, cabbage,bucks, greenstamps, Scratch, chunk of change,C notes, ect, ? HOW MUCH IS your intercooler with all the necessary components to hook up to a Stock 87 turbocharger with 2" od compressor outlet?
Would I want a larger inlet neck for future turbo upgrade?
What size is your inlet neck, ie 2.5" ID OR ??
2" ID TO 2.5" REDUCER HOSE IS included, as for the new bracket also
, SOUNDS SWEET
REGARDS, Blackhawk38
DON, CONTACT ME BY PRIVATE EMAIL here on the board to let me know the cost of PTE intercooler,
