SignUp Now!Isn't that off the vacumn block?
IMO --the best place is the 1/8 in. NPT port that is in the front of intake sorta behind the fuel pressure reg. It has a plug in it from the factory.
hook up a vacuum gauge to the pcv line and see what it does when the boost climbs. since it goes straight to the plenum, it will see the same boost as anywhere else will.+1 on everything Lee said. PCV is vacuum and doesn't and shouldn't see boost.
