Where to tap into MAP sensor for Power Logger
Sweet6
Like the title says. Is there a wire I can tap into close to the ECM so the logger can read boost? Or where should I tap into the MAP wire?
TIA
In that case tap off the MAP wire you ran into the car for the alky controller. The same signal is needed for the powerlogger. Thats what I did and it works great.
Jason
Thanks. I was just curious if there was a MAP wire under the dash to tap into like the GN.
