Here's an update:
I finally was able to get to work on the GN this weekend.
I replaced the fuel filter, oil and filter and the air filter.I also inspected the spark plug wires and have ordered a new set. I'll replace those and the plugs next. Two of the wires had a lot of red rust inside them on the coil pack end, so I cleaned the coil pack towers and also cleaned out the plug wire ends as much as I could. The old air filter was a mess. It was some kind of old school foam high flow filter, but the thing was falling apart, there was a big hole in it and all sorts of particulate in the air box. I hate to think about what might have been sucked into the engine. I sprayed the screen on the MAF with some carb cleaner to clean it up. I'm on my second fresh tank of gas and added some injector cleaner.
I was able to look the mufflers over while wrastling with the fuel filter...they are due for replacement as both have small holes where they have rusted through. I should probably replace the cat too since it is original....but the car passed smog with no problems.
The car is definitely showing improvement in power but I still have work to do. I still get some brief pinging at gear shifts when under boost up around or above 15psi.
Also, at WOT, the engine usually bogs. It's still slow to build power if flooring it off the line, and at WOT is usually hesitates quite a bit and sometimes pops/poofs from under the hood.
The odd thing is the car is actually quite strong and part to 3/4 throttle....it'll even break the tires loose a little in first if I ease into it until the boost hits about 15psi and chirps second gear.
The power, hesitation, pop/poof under the hood and ping issues are all at WOT. So something still aint right in the fuel air spark department...
The only other problem is at cold idle after first starting up in the AM. It will idle fine at about 1000+rpm for about a minute, and then the RPM drops, the car will almost stall, then it'll zoom up the RPM again to about 1500+ and then slow back to near stall...over and over while in Park. Once I get into gear and while still cold, it shapes up after some initial hesitation at tip in on the peddle. Once warmed up, this issue goes away.
Tim
