Which actuator???
3.8L V-8 eater
Hi, to all
My question is which wastegate actuator will work on a Turbonetics p-trim 70mm turbo??? I have a heavyduty actuator off of a TE-60 wondering if that would work??? The p-trim currently has an external d. pipe going to switch to a T.H. internal, so I will need to know what will work!!
Thanks!!
Tony...
It depends what housing is on it. My 76 has a bracket that bolts to the turbo then the actuator bolts to it. If the compressor housing looks like this one, then you need the bracket.
Rob,
When you come to pick up the tires you can check this out for me. I believe it is a turbonetics .63 ex. housing. It has a 2 bolt cap on the end of it and the housing is marked with a T on it.
