Which cam SHOULD i have?
87we410877
My motor is 30 over, balanced, blueprinted, 4 billit main caps, o-ringed ported and polished iron heads w/ big valves, 1.65 rollor rockers, intake matched to heads, 62mm throttle body, seimans 55lb injectors, streched intercooler, 3" down pipe, TA62 turbo , sx fuel pump, speed pro ECU. Car has a 10 second recipe by Andersons. I want to run about 25 lbs of boost w/ alchy. What cam should i be running. I have seen some set ups on here with less mods than me and bigger cams. I currently run an Erson 205-205 cam. Thanks.
Go roller.
U have a lot of money into the build so dont bail out now. Get a good hydraulic roller and hold onto the steering wheel. Theres been a few posts about cam selections recently, but I would all one of the Vendors that build motors and see what they recommend.
yea it is a hydraulic rollor, i figured the best thing is to call some builders. Thanks alot.
