I use a big cheap-o table candle (wax). (I recently came across some Castrol cutting wax that I use now.) While porting, I periodically dip the cutter onto the candle and hold it there for a second or two and the clogged particles fly right off. Use variable speed to help control clogging, too. When porting iron heads, use the chipped fast-cut (aluminum) burrs to relly remove alot of material. This will cut your porting time in half for the initial rough cut. Using double cut burrs (carbide) will take for ever to get the initial port work done. The deep single cut aluminum burrs really remove material FAST! After you try this, you'll never go back. The burrs are expensive, but well worth it. I keep the chipped/dull aluminum burs just for hogging cast iron.
