- Sep 1, 2008
I give the B penn oil a+++++ An if your buick is not leaking oil there is something wrong with it.
SignUp Now!I give the B penn oil a+++++ An if your buick is not leaking oil there is something wrong with it.![]()
I use conventional oil and a bottle of EOS. I will add ZDDP after my last 2 bottles of EOS are gone.
Yeah, if it ain't leaking it must be out ! :biggrin:
I've been using Valvoline VR1 Race Oil 20-50, might have to give the Brad Penn a look it's coming pretty highly recommended.
what is EOS??
what is EOS??
i just bought a bottle of ZINC-PER LUBE replacement additive...it says it has twice amount of high content ZDDP motor oils...anyone ever used thiss stuff...it cost $15..for a treatment..
There's more conventional oils out there than decently priced synthetics to choose from with proper ZDDP or decent antiwear additives for our cars.
There's also plenty of synthetics for more $$$ such as Royal Purple etc. that make good synthetic oils that don't need additives.
That being said Mobil 1 does offer one synthetic that doesn't need the extra additives some use, 15-50 weight.
It can increase leaks, it did on my 155K car when I switched over to synth., but wasn't nearly as bad as I thought it was going to be however.
A few extra drops a week not the flood I expected and that was in the old formulation Mobil 1 10-30 version too.
I'd probably stick with a good conventional oil which you can find with the SF, SG, SH, SJ, ratings that work just fine.
Kendall GT I believe is one.
Lots of threads here about oil so start reading.![]()
no!
