Which fuel pressure gauge
SS/GN
What is the best fuel pressure gauge,the small 1 1/4 permanatly mounted or the larger gauge with the 3 ft hose like caspers sells.Thanks for the input.:confused:
Kevin
Fuel rail gauges are only good for setting idle fuel pressure. You need to have something that you can watch while under boost.
Not that I know of anymore.... Go to Marks website (Guy who posted above, TR Custom parts) has a great new bracket to mount your fuel pressure gauge to, already powdercoated and drilled to fit your gauge mounting cup. Just order one of those, and a gauge/mounting cup from summit, some hose and you're set;)
I like the electric autometer in my A pilliar. Yes it was pricey but I can keep tabs on fuel PSI when in boost and it looks good inside the car.
