Well, the games afoot.
Since the only vehicle I have easy access to, and since it's my time and money, I'll be using my car. Not an exteme GN but it's realitively healthy. And since I'm using my own money, there is no need to try and please anyone with the results.
The topics are ease of use and accuracy.
And how much of a difference there is in resolution, and what effect that has on performance. Using this data takes the need out of having to use a 9 sec. car. While I'm sure some engineers might want to argue theory, this is going to be about real world.
Steve picked up a DFI from Lonnie over the weekend, and I've made arrangements with Steve to pick it up tomorrow.
And as fate would have it, I ran a sanity check on 1227749, Syclone ecm, to GN conversion today. I changed the injector BPC to a known good value, and changed some other misc variables for like the speedo and DIS patch. Then went for a drive.
The Syclone uses 30 PPH injectors, and I have 55s and a 36.
Tuning the cruise mode, idle, transistional stuff was about 45 mins taking my time using the Tunercat R_T, Romulator, and WB.
WOT still needs work, but close enough to be acceptable.
Cold start could take some polishing, but that's more time, then anything else to let the engine repeatedly cool.
And with the DFI having it's own harness that means plugging it into the ecm bench is a given for testing.
And with TurboLink working on the Syclone stuff I can read PW to .00 msec., and timing to .1d...
So far, buying used, like the DFI is, the ecm is $35, $15 for the adapter pieces, $100 for R-T, $130 for the Romulator, and $150 for a used DS. I haven't seen a used T/L hence the DS price for the scanner. So far the used DFI at $300 is winning, pricewise.
The 3 bar MAP is a given since both use it.
The ecm bench is also just a common enitity.
I'm ignoring the price of the transistors for the oem ecm, since this isn't a race car, and for this level of performance using saturated injectors would be fine.
I'll be running both ecms, in car, and on the bench.
Normal disclaimers apply.
No EE's hurt in the commision of this testing.
Your Mileage WILL vary.
Not to be attempted without adult supervision.
A Special Thanks to Ken, Lonnie, and Steve.
