1KWIKSIX
- Sep 29, 2007
with a 1/8 bore i assume you are disc all the way around?
Nope, Discs up front & drums on the rear. Running a HydroBoost set up.
SignUp Now!with a 1/8 bore i assume you are disc all the way around?
Now this one looks the best!Does it have to be Wilwood? Did you look at Baer?
Master Cylinder is 1-1/8” bore Wilwood #260-8556-BK with Wilwood Adjustable Proportioning Valve #260-1170 with RH Proportioning Valve Bracket #220-15047
What hydroboost you go with? Thanks for the info...
How do you like that prop valve?
Playing with the idea of putting an adjustable one on and plumbing it in a similar manner
i think the polished reservoir is what would match best...View attachment 327798
Did a Wilwood unit when I went Hydratech Hydroboost, brakes never better !, Used a speedway adjustable prop valve, but I am now going 4 wheel disc, Wilwood, what are my options on residual valves ?, Will re-plumb my line lock at the same time.
Want to replace the factory PS pump too, it makes noise, Turn one ???
That works, thanks, will go shopping
That is how I did it for a customer last year.Keep in mind that placement of the residual valves should be as close to the master cylinder as possible.
