Thats pretty normal. Oil loses "thickness" when it heats up. Thats why it says 10W-30 or whatever. It will get no thicker than 30 weight when its cold, and no thinner than 10 weight when its hot. Colder 'thicker" oil will produce more pressure. This is totally normal and I wouldnt worry about it. You are seeing the natural effects of the oil. If the oil gets hotter and hotter and hotter, it will get no thinner than 10 weight and you will see the same oil pressure as before (unless you're so blazing hot that the oil is falling apart and coking...which is highly unlikely unless you're going WOT for 5 minutes straight with water coolant temps at 250 degrees). Thats the advantage of synthetic oil. It takes a much much hotter temperature before it starts to fall apart.
Im not running any oil cooler at all right now, as alot of people are doing. If you can keep the block cool through the water coolant system, the oil will stay cool. Oil coolers are great for road racing, where you're staying in the throttle for long periods of time, but not for most GN applications. If you're worried about your paltry 50psi, go to a thicker oil...but at that point, the oil wont drain back to the pan as fast. Now as far as the oil going through the turbo, and the turbo having no cooling system..so what. The oil spends practically no time in the turbo bearings. It passes through very fast, and if you run synthetic, there is nothing to worry about.
