D dalesteraz Member Joined Sep 19, 2005 Mar 18, 2010 #1 088 pump body, I have a couple of different regulator valves, with passage thru valve and without, wondering which to use?
S SSedan64 JoaTMoN Joined Dec 8, 2007 Mar 18, 2010 #2 The valve with the hole will only work in the 088 casting stator. If not, severe pressure problems will result. Info here, about 3/4 way down page.>> Answer Question
J jakeshoe Member Joined Nov 19, 2002 Mar 18, 2010 #3 The valve with the hole is OK to use in all the pumps. The one without can only be used in the early pumps.
