Freddie's Buick
Hell No! I'm not a junior
- Jan 3, 2002
damn i wonder what will happen if i use my stock pistons...the machine guy said the were in good condition...and use the comp cam with stock valve springs and lifter...would this combo work ...i dont plan on racing... I also plan on sealing the egr port...
Did you read this?
With lifts above .420 the retainers will hit the exhaust guides. Cams with lifts above .420 need the guides to be shortened. A professional Buick engine rebuilder would know this. It has nothing to do with deck clearance or IC engines. Just the way V-6 engines from '75 on up are designed.
If the engine needs a cam, get a OEM stocker from a GN for a little more 'umf'.
No need to cut anything on the heads.
If you go higher lift, more work, more cash, more time. In addition to that, you may have to get after-market valve covers for the higher clearance.![]()
Good luck!
