turbo96max
- Jun 6, 2007
Guys,
I have been trying to research this topic but I have not found much .
Im looking into the info for stock stroke steel crank for a girdled,eagle rods,je's, roller cam,ported iron setup.
Goals are solid 10.30 -10.70s maybe 3-5 times a year track appearances and a lot of street killing weekend warrior. The car will see rain and get use , tired of seen it in the garage. Full weight car with AC, which at times makes 2 trips a week to work (highway). Pretty sure a stock crank will get it done but the engine block im using has a 030 cut crank and I would like to not worry and have reliability at said power levels.Car still is running on a trw arp motor in the interim.
A few questions im hoping to get some help on:
1. what brand of crank are most users using lately that dont require too much additional machining and hence added costs ?
2. Any input on recent usage of eagle vs gn1 vs scat?
3. at what power levels are people using 4340 vs the 4140 'steel'?
thanks for the input and for sharing
