send me a pm with what's on your mindMy Talon...
CTR4X 6262, T4 twin scroll 1.0 AR, don't see that option?
SignUp Now!send me a pm with what's on your mindMy Talon...
Dynoman, can you talk about the details on the housing and post a picture, nice. I'll assume like .82 and v band outlet DP flange?
Can you comment on if they did a custom for you or if they already had the exhaust housing for us and it wasn't a big buck custom tag?
It looks like street/strip cars use the water cooling but oil less turbo. Air cooled is mainly for those with exposed turbos.
most likely they are not compatible.Curious...
You think HPT would sell their exhaust housing separately?
Could be a great combo even if you pay a premium for the housing.
The wastegate needs to be in the header to give proper control and proper backpressure number of how the turbo system truly works.I was most curious about the wastegate being on the housing to eliminate the weak point of actuator. The combo of hubless turbo and wastegate on the ex housing would be a killer 2024 combo for
Those are called adaptersThanks for the info, I was unaware that pulse control at the ex housing was inferior vs the manifold.
Concerning all these new turbos coming and running stock 3 bolt, T3, T4 or V band that are all different depending on brand.
I asked my fabricator if a multi turbo flange option was possible where you cut off a few inches below the main turbo flange, create a v band there (say Garrett) on the stock manifold and then make short pieces off that which puts any turbo flange on the turbo end you want so you can effectively run any turbo from that point forwards. I'm in this situation, I can only run Garrett turbo v bands but the idea above would allow anyone to run whatever turbo flange they wanted buy just creating the new turbo end piece to match. It would be the first unisex turbo manifold on the planet. LOL
I have a few carsWeld on adapters are great if you choose T4 to start, but V band isn't a unified size between brands so it's a mess.
Manifold side V band = Garrett
Maybe 3" of tubing
Turbo side V band = whatever you want
This way since Comp uses Tial v band size you swap out this double sided v band adapter for Comp, then say Garrett does a better hubless later on you go to Garrett etc and get a 2nd small adapter joint made.
The above will make it easier for us to jump to different turbo brands since the 3 bolt is a PIA for them all and not as efficient as you've stated.
You running T4 Spool?
V band is nicer for oil return, getting on or off quickly, lighter and room around the flange in general.
