Thanks guys in comparing "kits" dse is about $500 more w all the same options w/o the ball joints. Any input as to what makes it better? Usit just more sorted out?
dse
$2115 front
Speed Kit 1
• Tubular Upper Control Arms
• Tubular Lower Control Arms
• Front Replacement Shocks (Shocks are DSE valved to match their springs rate and the timing of the jounce)
• 2” Drop Coil Springs
• DSE Tubular Anti-Roll Bar
• Chassis Braces Also designed to clear the stock inter-cooler, or front-mount inter-cooler pipes.
$1510
• Patented Swivel-Link™ Rear Control Arms
• Dropped Rear Spring Kit
• Rear replacement Shocks
• DSE Tubular Rear Anti-Roll Bar
Total - $3625
$2275 Our most popular package includes:
1. SC&C Stage 2 Plus kit - SPC adjustable front upper A-arms with greasable delrin bushings and offset pivots, on 4130 chrome moly cross shafts, and Howe Precision series Xtra tall upper and tall lower ball joints.
2. SPC Performance Pro Spring kit (F+R).
3. UMI Performance rear Roto-Joint/Poly tubular lower and adjustable Roto-Joint upper control arms.
4. Hellwig tubular sway bars - 1 5/16" front, and 1" adjustable rate rear.
5. Bilstein H.D. shocks (F+R)
SPC Performance Tubular Lower A Arms / SPC Spring Seat Spacers / Progressive Rate Jounce Bumpers add $649.90
CHASSIS BRACE GM The Grand National version is designed to clear the stock intercooler, or front-mount intercooler pipes. Now includes the correct metric mounting hardware, including the GM specific 10mm thread forming screws.
$189
Total $3115
