Whats up Dirtbag.. Man ive waited to say that for a long time
Keep the stock injectors,ic, and turbo if the turbo is in good working order....
You will only make more power with a larger turbo (44/49 ect) if you can turn the boost up past 21-23psi. (50 HP only if you have the octane to support over 21psi)
here is the point!!!
Get a meth kit and turn the boost up on the stock turbo, My daily driver runs low 12s on radials and pump gas.
YOU WILL MAKE MORE POWER WITH METH ON THE STOCK TURBO AT HIGHER BOOST THAN A 44 TURBO ON REGULAR PUMP GAS...
Whats the point of running a larger turbo, buying a larger set of injectors,buying a larger convertor, JUST TO RUN LOW BOOST CAUSE YOU CANT AFFORD THE OCTANE???
I tell you what, i wouldnt praise it if i didnt love it, meth kit, eric chip,high boost, high timing, more power, bigger grin....Mine bone stock long block, stock turbo,IC,ING 356HP/556TQ drive it everysingle day, blow the tires at will and still leave off the streetlight off idle, can kill everycar ive raced for 2 years on the street....
I havent been getting responses,
wanner@kc.rr.com
BW
