haywire4130
- Sep 11, 2010
hello all, i'm doing my homework before ordering rebuild parts, it's quite the process, lots of choices. quick history: engine was built 1k miles before i bought the car... previous owner thought the alky was optional and ran the tank dry at 26 psi. needless to say, it toasted the cometic gasket around the #1 cyl, and hammered the rod bearings pretty hard, hence the tear down. it has forged pistons on polished stock rods, crank is std./ std. and remarkably still looks good, 212 cam, girdle, and ported heads with stainless valves which brings me to the first of many questions: a few of the valve stem seals are torn, the top half with the spring ripped off and is floating on the valve stem about half way up. is there a "best" seal to use (rubber, teflon or viton)? is this a common problem? they look like rubber oem style to me but i havent removed one yet. possibly interference from the valve springs? any info would be appreciated!
