Which way does the flex plate go on
GregP
Does the converter side of the flex plate have recesses or raised areas where the converter feet attach? If I put my TCI flexplate on with the SFI inspection sticker towards the trans, the converter feet will mount to recesses. If I put it on with the SFI sticker towards the block the converter feet will mount to raised pads.
Which way is correct?
-Greg
The converter needs to mount to the raised portions. If it mounts into a recess, the pump might not engage the converter snout properly.
Thanks. Just seemed strange that the SFI sticker should face the block, but I guess that way they can read it if the drip pan is off.
-Greg
