Which wheel studs for Moser 30 spline axles?
Hi,
There is No difference to my knowledge , except for how they are installed. When using the screw in style, be sure to torque them properly. I applied loctite to the studs (I applied the loctite after the studs were screwed in about 90% in, then applied loctite to the screws from backside of the flanges. Don't want to get loctite onto the area where the lugs are going to cover). Double check the studs every time you remove the wheels and reinstall them.
