meanchicken
gallo vicioso
- Oct 6, 2007
What's this wires purpose?
Last night I was driving about, and all the sudden I started getting a intermittent SES light with the engine cutting out for blip and then back on.
It would happen at about 2500-3000 rpm under light/normal acceleration as I accelerated from a stop and then go away when I took my foot off the peddle or when I evened out the peddle pressure and cruised.
Got the GN home and started looking around under the hood for anything obvious/usual suspects.
I found that my harness going to the ign module plug was resting against the rear most intake manifold stud, and had chaffed through the elect tape. The insulation for this white wire with the orange stripe also appeared to be nearly chaffed through. I moved it way from the intake stud and put a little rubber cap over the stud to keep it from chaffing the wire more and it seems to have cured the problem.
I'll still need to go back and make a proper repair of the harness and wire, but I'm just wondering what signal this wire carries.
Thanks!
Tim
Thanks!
Tim
