Darkstar72
- Oct 1, 2017
I got my intake off last night going through and sealing up top - intake manifold gaskets, valve cover gaskets, turbo drain gasket, etc.
Since I don't want to do this job again any time soon I am replacing the PCV grommet and PCV while I have it all out on the bench. I see conflicting information from Kirbans' measurements on the opening versus the sizes mentioned on Highway Stars.
Per Kirban site on grommet - "This replacement PCV valve grommet also had the wrong size relief. It measured only .175 instead of .230 in the original. The center hole measurement was .440 instead of .495."
Per Highway Stars - "This grommet was engineered to original GM blueprints and features the correct .485" hole diameter for the proper seating and sealing of the PCV valve."
Looking for anyone that can give some insight into this. Anyone have experience with either grommet to truly say which one will work the best? The cost of the part is obviously not an issue from wherever I may get it from as these are not expensive parts, but I HATE doing the same job twice. TIA.
