Who knows Reds chips
snipersixx
Anyone know what kind of timing Red Armstrong puts in his race chips 106,107,108 and the boost they were able to run with them. Just in case with C-16 of course.
Also what kind of 02's and egt's were you able to get thinking I may need to change chip people.
Cars 02's always fat 8.20 and egt's high 1670-1695 and that's getting out of it at 105-110 mph.
sounds like you have a 107 chip-
timing is low at 18°
EGT will be high because its so rich
what are the numbers are on the chip?
sounds like you are running 20 psi of boost and have bigger injectors???
let us know
BW
Reds Chips
let us know
BW
No I have tried the 107 and changed to 106 chip with c-16, 75lbs. injectors and 25lbs. boost still not happy with the egt's and these chips performance, also 45psi of fuel pressure with line off.
Something not right.....
