I was running 30 PSI on 93/alky but recently I replaced my WG hose(wrong size,,replaced the T in there as well with the PROPER one) and with my hose plugged into the solenoid,I can only hit 15 PSI.Ive simply unplugged the hose to the solenoid to hit 25 PSI
.Doesnt help when I crank the adj WG down and im certain its hooked up right(tried every way and I called someone and had him look at his to ensure I put mine on proper).
And my WG is an HD unit from Limit.I thought the HD WG's wouldnt go any lower than 18-19 PSI
Boost doesnt spike at all and its spooling fairly quick considering it has a stock convertor.
