I have the fast system on my car, the car started running very rich
and dumping black smoke all of a sudden, I tried to change the
ve fuel settings and not much difference. I then took it out of
closed loop and adjusted the tables to lean it out a bit it and it
got better. I check the dash sensor's and UEGOS (v) is in red,
and reads 0.88 is that normal? I've checked the coil pack, wires
vacuum lines etc. all are fine. I need some direction on this please
Is there something else I should be checking to diagnose this
problem??
problem??
